Hi there, i need thi bios to be fixed, the laptop turns on, caps lock and num lock light up briefly, the fan starts spinning quickly, no image. Thanks
if your clear me file have same result then the issue is not related to biosits not working, all the same
do you have another bios? now lights up the wlan and speaker LEDs, which was not the case beforeif your clear me file have same result then the issue is not related to bios
please check the motherboard carefully
the motherboard looks fine, 3.3 and 5V voltages are present, no signs of short circuitdo you have another bios? now lights up the wlan and speaker LEDs, which was not the case before
this is latest update bios file for this device which is most exact file available :the motherboard looks fine, 3.3 and 5V voltages are present, no signs of short circuit
finally working! thanks!this is latest update bios file for this device which is most exact file available :
